FX4OffRoad1992
- Aug 10, 2010
- Age
- 32
- Morehead City, NC
- Automatic
What kind of inspection do you have. One where a guy looks over your vehicle to check for stuff? Is it an actual emissions test with an exhaust sniffer while driving on rollers.
In WI it's a half-assed emissions test. Only vehicles 96+ (OBDII) required to do it. Basically they just hook a scanner up to the OBD-II DLC, if you don't have any active or pending trouble codes, and your gascap passes the pressure test (they might not even test the gascap anymore) you pass.
My Grand Marquis had 4 cats (1st O2 sensors, cat, 2nd O2 sensors, cat, y-pipe). I cut out the last set of cats. I pass the "emissions" test. It passes. It definitely wouldn't pass a exhaust gas analyzer/sniffer.
around here they just look around the truck checking lights and blinkers.. and then hook it up and if it doesnt throw any codes your fine.. im pretty sure they don't do the whole exhaust gas sniffer thing.. so im not sure if i would be okay without the last cat or not..
