Transmission Crossmember Bushings
Railer150
Hello All,
Since my truck is being lowered soon, my cross-member has blown bushings and i know they are non-serviceable but i was wondering if i switch to the cross member from illusive fabrication, will i have to change my trans mount since there are no bushings in it, i have Turbo 350 trans right now behind my small block Chevy and really dont want to crack my bellhousing
Fab your own or find one from a newer ranger without the bushings. All you have to do is grind the old rivets out of the old frame mounts and remove it. The new cross member will bolt up in those holes and you have to drill a new hole on the opposite side.
