Transmission Bolt Torque Specs
BigPimpin91
I'm trying to bolt my new M5 to my 2.9l and I can't seem to find the torque specs.....
I thought I had read somewhere that they were 38lbs...
I need transmission to block torque specs.
Transfercase to Transmission specs.
Driveshaft to transfercase specs.
Crossmember specs*. (The one that supports the trans.)
Transmission Mount specs*. (The nuts for the rubber piece.)
*If these matter significantly...
Thanks! :headbang:
Opinions vary... I have always just put them in so they are "tight." Never had a problem. Some sticklers will go the extra above and beyond and torque them but IMO it's not necessary.. just my opinion though...
I also had a mishap with my hardware.
Here are some pictures.
Main group.
Long Ones
I know these are the starter bolts.
I have washers on these ones, are they supposed to have washers or did the washers get on there by accident?
Also, what size bolts and grade will I need for the transmission to transfercase bolts?
Those seem to have walked off as well...
Ballhousing bolts ~40ft/lb
The tranny mount bolts ~50ft/lb
The nuts to on the tranny mount studs 75ft/lb
And you'll notice those washers are ALUMINUM to protect the
bellhousing from the steel bolt head.
AD
