Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS Banner 2012-2015
GMRS Radio License
TRS 25th Anniversary
- Aug 2, 2000
- Age
- 57
- Nocona
- State - Country
- TX - USA
- Other
- 2005 Jaguar XJ8
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3 EcoBoost
- Automatic
- Total Lift
- 3.5-inches
- Tire Size
- 295/70/17
Tech Library:
1983-2011 Ford Ranger 4-Wheel Drive Systems:
Transfer Case Doubler:
Warn is no longer making manual locking hubs for the Ford Ranger including the Warn 37780 Jeep Hubs. The stronger replacement is now the AVM 465XP. See: AVM Xtreme Performance Hubs For The Dana 35.
To see a complete list of the manual locking hubs that are available now that Warn is no longer offering them, check out: Ford Ranger 4×4 Front Axles: 1983-1997
If you know of any forum posts or links from our Tech Library that should be listed here, please let me know.
Ford Discussions:
If there are any threads here that should be included in these FAQ's, please let me know.
- The 1983-2011 Ford Ranger 4WD System -How It Works
- 1983-2011 Ford Ranger Transfer Cases
- Transfer Case Identification & Ratios
- Borg Warner Transfer Case Identification
- Transfer Case Troubleshooting
- Troubleshooting Your 2001-2011 Transfer Case
- Transfer Case Fluid Change
- 1995-2000 4WD Control Module
- Checking 4WD Shift Module Circuits (1994-Older)
- Transfer Case Shift Module Diagnosis (1994-Older)
- Dual Transfer Case Conversion
- Building a BW1350-1354 Transfer Case Doubler
- D&D Machine Transfer Case Doubler Install
- 1983-2011 Ford Ranger 4×4 Locking Hubs
- Hub Troubleshooting
- Automatic to Manual Hub Swap
- AVM Xtreme Performance Hubs For The Dana 35
- BlackBII’s Dana 35 Spindle Nut Mod
- Manual Hub Bearing Replacement
- Securing Your Hubs To The Rotors
- Tightening Your Spindle Lock Nuts
- Dana 35 Jeep Locknut Upgrade
- Warn Dana 35 Locknut Conversion
- Dana 44 Knuckle – Locking Hub Conversion
- Dana 44 Knuckle & Locking Hub Swap on a Dana 35
- Beefing Up The Ford Ranger Dana 35 TTB
- 1999-2000 Locking Hub Operation & Troubleshooting
- 1998-2000 PVH Hubs Diagnose & Repair TSB
- Troubleshoot/Fix Your 1998-2000 PVH Hubs
- Adding Manual Control To 1998-2000 Pulse Vacuum Hubs
- Permanently Lock Your ’98-’00 Vacuum Operated Hubs
- 1998-2000 Hub Bearing Replacement
- Rugged Ridge Hub Upgrade For Vacuum Hubs
- Manual Hub Conversion For 2001-Up Ford Ranger
- 1998-2000 Vacuum Hub – Live Axle Swap
Ford Discussions:
