Trans Swap Nightmare
FordracingBII
Fort Smith Montana no sales tax and nobodys trying
1997
1997
If your going to do trans swap from an A4LD to anything pay attention to EVERYTHING! There are driveshaft issues, Transfercase shifter, Clutch / Flywheel, Flange(on the transfer case), computer and other yet to be discovered issues.
On my swap I figured I would get a donor BII same year w/ 5sp and that way I would have all the parts....ez enough just unbolt off one and bolt on to the other ...well.......nothing is that ez.
Since I had the 5 sp out I figured I would let a trans shop take a look at it......shoulda known....:bad:..they found $800.00 worth of "stuff" ( It worked fine when I drove it home) so I told them to "stuff it" :annoyed:
Found a transmission shop that had a remanufactured 5 sp $600.00 thats $200 less than going the other way so I bought the reman.
Fast Forward....
Okay, got it all put back together......fired it up......BAD SOUND>>>SHUT IT DOWN Hmmmmm....gotta pull it and see what happened (good thing I didn't put the ex system or drive shaft back on).
Throwout Bearing "Grenaded" "What the Hell Happened"?
When I exchanged the trans I did not notice that my core had a "snout" or "quill" (it's what the throwout bearing slides on)
and the one I bought did not. No Snout = Grenaded Throwout Bearing
:idiot:
So what I have is a newer 5sp trans(requires an internal slave)- No Snout,
bolted to a older Bellhousing (external slave) with a external slave hydraulic system :pissedoff: Does any of this make sense?
So now I have to find a bellhousing for a 2.8 that will use an internal slave...anybody have any Idea how hard it will be to find?
I'm affraid i'm going to have to raise the flag on this one
:bsflag:
Can I still use my master cylinder?
