trans question
12gauge
will the 4.0 trans interchange with the 2.9 engine as far as ithe bolt pattern in the bellhousing thanks
You can either use a FM-146 or a M5OD. It most likely came with the FM-146, you can tell by looking at the bottom of the transmission. If it has a flat plate with a drain plug its the FM-146. If there's not flat plate it's the M5OD.
The M5OD is the superior transmission.
You can also use the FM-145 if absolutly necessary, but it is 2" shorter so it would require a few mods and is not a very desirable transmission.
ok ty
ok i have the mits fm146 does any other vech use this trans fm146 and the m5od what b mazda seires will work? 2000? 2200 ? ect? only reason i ask is i have a non domestic salvage yard near me that has lots of mazda pick ups
