BroncoII93
I have an 88 bronco II that I just completed a trans swap on. When I replaced it I also replaced the gear oil, whole clutch, slave, and master cylinder. However, after I got it on the road it started making this horrible noise when it's in gear except for 4th. It sounds like the trans is eating itself in all other gears. What could be causing this noise? The trans is a FM-146 with a 1350 manual shift t-case.
