Towing Capacity with Manual Tran
sgrbear
I am shopping for another Ranger after rolling mine and found a cherry 2006 fx4 L2 with a manual transmission. After reading Ford's towing guide I see that an automatic super cab 4x4 is rated to tow 5000 + lbs. with a combined gvw of 9500 lbs. but the manual tran is only rated to tow 3000lbs. What is the deal with that? Is it the clutch? The truck is also "screaming yellow", not sure about that either???
Towing capacity, as far as the transmission, is based on the possible failure of components when the extra weight is added, autos win out.
Secondary, but still considered is the drivers needed skills, autos win again.
Most drivers who have used clutches, and prefer them, will argue the point, but legally it is a moot point.
The manufacturers listed towing capacity is the legal number.
And FYI even if you were to swap the manual and put in a stock Ford auto, that truck would not get the higher weight tow rating, "as manufactured" would be the legal limit.
The legal limit only comes up when you want to rent a trailer or if, heaven forbid, there is an accident, if fingers are being pointed then the weight might come up even it wasn't a factor in the accident.
Yellow is nice, but I prefer Red :)
Gear ratios also affect the amount that can be towed as well, the higher the gear ratio (the lower the actual number) the more can be towed. I know that with my 96 2.3L 5 speed with 3.45's it says that towing is not recommended, at all.
This has been gone over quite a few times.
The consensus has been that it has become normal for manufacturers to downrate their manuals because not everyone knows how to properly drive one with a loaded trailer behind them, it takes a little different driving style to do it correctly than just bumming around in a manual shift vehicle. Improper driving with a manual can result in a toasted clutch, warped components, and other driveline damage.
An auto takes that issue out of the equation. You let off the brake and hit the gas and it goes by itself. A lot less to fail. Well, at least as long as you don't overheat the transmission.
A manual trans truck will handle the extra weight, period.
Trailer brakes are always a big help.
If you're going to haul heavy trailers often, think F-150 or bigger. Yes, the Ranger may handle it, but a larger, heavier truck will handle it better.
It is possible to upgrade your suspension, drivetrain and braking system then apply to the DOT to have your legal weight limit raised. It's a lot of effort and it has to be well documented, but it can be done.
I think and this is my opinion. It has to deal with 2 things taking off and stopping. The automatic is more forgiving than a manual. The shock to the driveline components is more severe in a manual than an automatic when moving from a stop. If you look up recalls for 02 FX4's you'll see that they were cracking the top of the rear axle. This would also be true for stopping and downshifting. I'm not going to get into clutch problems. Of course it could be that they want to sell more autos, so you make it that the auto has a higher tow capacity and you sell more autos.
Thanks for the replies and information. I finally pulled the trigger and bought a red 06 fx4 with an auto. It has 55k but is cherry and has been officially adopted to its new home on the farm, days of easy living has ended for this ranger. Now I need to find someone to install a neutral tow kit so it can go on vacation with us.
If I took an auto Ranger and swapped in a manual transmission would I "legally" still be able to tow with the higher rating? My Ranger doesn't really see that much weight behind it and when I do have anything heavy to tow I keep a 1 ton Chevy around just for that purpose but I figured i'd just throw the question out there.
I am considering using my 4x4 1999 Ranger with manual trans to tow a project vehicle home on a car dolly. The car weighs under 3200 lbs, which is what the owner's manual says is close to max. Car dolly will probably only add several hundred pounds more. Drive is local and flat on a road that will probably be under 55 most of the way. I will have to try and convince u-haul to let me tow with my configuration.
Real question is for manual transmissions, are there any tricks to towing other than taking it slow and easy?
Good luck getting u haul to do it.
But lets say max 4000lbs with the dolly....itll be no sweat.
As far as the trans, just avoid riding the clutch, get it up fast (but easy)and let the engine do the work.
Yea u-haul goes by the book for legal reasons. If you crash your truck because they rented you a trailer or dolley your vehicle isn't spec'd for and they could get sued. Doesn't matter if your truck physically can do it, its whether or not its legal according to the manufacturers specifications.
Get rolling and release the clutch as soon as possible, avoid "feathering" the clutch as much as possible
Use the engine to slow down as much as possible, down shift, dolly doesn't have "trailer brakes" so truck brakes will heat up more when stopping with the extra 3,000+ LBS
Manuals are weaker than automatics
M5OD-R1 is rated at 330ft/lb torque
4R/5R44E is rated at 440ft/lb, thats what the 44 means
4R/5R55E is rated at 550ft/lb, thats what the 55 means
Tow weight rating never had/has anything to do with drivers ability or clutch, thats a myth
It all about the numbers, ability to GO, and ability to STOP, without breaking anything
Also the trailer hitch can limit towing weight
I’ve towed Bronco IIs behind my Rangers a number of times with no issues. Always told U-haul I was moving a Geo Metro. Legally I can pull the B2, but U-haul said no, too heavy.
U haul said my 87 ranger on a dolly was to heavy for my 77 F250.
Sometimes i think they do that to entice you to rent their equipment
The brakes on a dolley are pretty much useless. That also plays into it.
All great advice. I didn't think of downsizing the car. I can use rent the tow dolly for a toyota yaris.:)
I pretty much drive all the time like was described above... except for the engine braking which is a good idea. I was thinking of also bringing along a non-contact thermometer to keep my eye on the diff. It whines a little and I don't want to overheat it.
