tklepp
- Sep 11, 2017
Hi - new here and I have a doosy. 88 B2 w/ 2.9 manual
It sat for 6mths and was ran out of gas.
Supposedly the t/c was stuck in N.
The engine wont turn over so I towed it home.
Bought it for $250.
I found a small bit of gas at the fuel regulator but after tinkering with it and the fuel line it is now dry.
I dumped a couple gallons of gas in it, dumped the old oil and coolant.
Put fresh stuff in it and sprayed carb cleaner in.
It tries to start with the cleaner and Seafoam.
I checked the inertia switch - seems fine.
How to test the Fuel Relay? In simple simple terms please.
Any ideas on being ran out of gas?
Can you just cut out the inertia switch out and wire together?
Thanks in advance for your help.
see pic
https://drive.google.com/open?id=0B3TUPUdw-dchSUxMNk8tdUFJZ2F0MHJGQWVLcWh3ZVU4Y2lN
Bought it for $250.
see pic
