Paladin5469
- Apr 5, 2015
hey guys, i have a problem timing up my engine on my 1994 ranger while changing my timing belt.
ive done a little bit of searching, ive checked diagrams, but my engine is missing timing marks for the auxiliary sprocket. I can time the crank sprockets and cam shaft just fine, but just not the auxiliary. Also there's only one peep hole, none for the auxiliary cam sprocket. There are no diamonds or marks on auxiliary or timing belt cover.
also there is a sensor on thee crank shaft sprocket that is absent from all the diagrams ive seen so far. Advice would be greatly appreciated. thanks in advance.
