Buffalo
- Mar 26, 2011
- Automatic
The front of my 2002 3.0 started leaking around the gasket on the timing chain cover. It's got coolant and oil seeping out, but no coolant in the oil or vice versa. I'm thinking it should be replaced sooner than later before it catastrophically fails.
Anything else that should get replaced while everything is apart? Timing chain? Tensioners? Oil pump?
