DumpsterGuy
Hey everybody. I'm mostly wondering if there is a way to set up the throttle linkage for a Holley 390 four barrel while keeping the stock cruise cruise control setup or should I just forget about it? I've never swapped to a four barrel before. I had a Holley 350 for a while, and that was almost a direct bolt on. I've seen the generic setups at parts stores. I was just wondering if there was a better way.
I've been searching the forums, but couldn't find what I wanted.
I have an 84 Bronco II with with the 2.8. It has cruise control from the factory which worked fine before pulling the old motor.
