farmerscotty
- Jun 1, 2008
- Manual
Ok have a 1987 2.3 Ranger......took out and replaced the thermostat 3 times. took out heater core cleaned the leaves out of it, flushed it with cleaner (lime away) and it flows good. but my truck will not get warm idling until you drive it (motor faster). it will finally get into the normal range on the gauge just to the "m". I need more heat............can the water pump be bad ??? and what is with the "t" on the heater hose going to the back of the head? could that be part of my problem.???
I have felt of the heater hoses and they are both warm-hot..........
freezing in missouri...............
Scott the farmer in Ozark.
