I've been seeing guys with a Hurst style shifter for their trucks. If anyone was interested in seeing how I built my shifter lever, I will do a brief write up.
So I put this together using the following supplies:
1. Piece of flat-stock steel from Tractor Supply.
2. One M12x1.75 bolt. About an inch-and -a-half long.
3. The shifter stub from a M5ODR2 transmission.
4. Two 1-inch 5/16 18 bolts.
5. Two 5/16 lock washers.
6. White shifter knob from Americanmuscle.com for a foxbody mustang.
The tools used were:
1. Oxy acetylene torch
2. Wood block
3. Table vice
4. Tig welder
5. Bench grinder
6. Punch and hammer
7. 5/16 18 drill bit and tap
8. Cookie wheel and polish
9. Clear coat
Take the shifter stub out of the transmission and grind the driver side of the stub down about a quarter of an inch. Then grind the passenger side of the stub just enough to make a nice even flat spot.
Then drill two holes in the center of the stub, use lots of lube and work slowly. The stub is harder to drill through the passenger side for some reason. You can tap the holes or use a bolt with a nut. The nut and bolt method works better.
Then you need to decide what shape and how long you want the shifter lever to be.
Make a mark the same length as the grindings on the stub of the steel.
Then measure where you want your first bend to be, cut down your flat stock leaving extra material on each end of your steel so your bends dont make the shifter too short.
Using the vice and torch heat the metal till glowing red where you marked it for the first bend. Use the wood block and butt it against the marked area while red and SLOWLY pull the top of the steel back towards you until you reach the desired bend. Cool the steel down and check your work. Mark where you want your second bend and repeat, pulling the steel SLOWLY towards yourself. Cool down and check your work.
Cut the extra length off the bottom, drill the holes and test bolt together. Then cut the top down accounting for the bolts and balls length.
Weld the bolt to the steel then grind the steel and bolt head smooth.
If my ramblings made any sense you should have something like this
Using the cookie wheel and polish, clean it up and clear coat it.
I have very little time into this and im not a great fabricator so its not as bad as it sounds.
I uesd an F150 noise isolator.
Attach your new shifter lever to the modified stub.
http://imgur.com/a/MFK3lNX
End results are.
http://imgur.com/a/AiRVRu1
I also cut down an Advanced Auto cup holder/cd holder to fill in the gap.
2. Wood block
3. Table vice
4. Tig welder
5. Bench grinder
6. Punch and hammer
9. Clear coat
End results are.
