Brain75
- Aug 8, 2024
- ~Sterling, Colorado
- 2.9 V6
- Tire Size
- 215/70R14
swinging back and forth between N and O tells me it is a real gauge (not an idiot light/"centered needle") and it is doing exactly what it is supposed to, when the engine builds up to thermostat open it is climbing, the thermostat opens, "cold" coolant (like 120 degree) rushes in and quenches the gauge... if you want it to read between R and M then install a standard 192 degree thermo or the appropriate resistor to get the right resistance. If you can live with it swinging between N and O and REMEMBER that is what it is supposed to do, then you got it working perfectly.
