Tach Dual Coil Pack Question
RedRyder97
SW Michigan
This is for the 4 cyl 2 coil pack set up.
I think I found a great photo to use or should I say wire schematic on another ford page. I thought I would share with you all. I did a Google search with this number and the photo will come up. 97612d1272841370‑running copy and paste that and you will see the wiring diagram remember to set the Google search to Image.
Adding a aftermarket Tach. To find the coil or tach lead wire connection.
