rurouni20xx
heres the rundown: i hav a 92 ranger 2wd 2.3 m50d supercab that im slowly rebuilding, chassis/brakes and driveline are approx 60 percent complete, looking into building a longblock and dropping in her. going to rebuild for more power without boosting (nothing against it but this is my dd and downtime for tuning needs to be kept to a minimum, no dyno available.) been looking into this for a while and have several questions concerning different rotating assembly combinations compression ratios and cylinder heads. they are as follows:
1: stock crank/rod length or stroke it?
2: if stroker is used milled 2.3 crank w/ chevy 5.7 inch rods or 2.5 crank and rods?
3: what brand pistons/rods would you recommend? looking at wiseco pistons and crower rods, never heard of keith black what are your thoughts?
4: seems all i can find are dish 8:1 and 9:1 compression ratio pistons, are higher cr available? looking to build 11:1 if possible...
5: on stock cylinder head are there larger face valves available and where? (would look up valves per the dimensions but i dont have a 2.3 head torn down so i can measure everything.)
6: stock head decent street/strip cam what are general specs for one? want to look at potential options/recommedations...
7: adjustable cam gears: reading on some models (racer walsh) that they will not work on a ranger engine, why not?
8: underdrive pulleys/lighter flywheel for street use good idea or not?
9: b234 volvo head, have not found one modified and dont want to go thru the headache of modifying one myself but havent ruled it out, how would you convert the 8 plug ignition setup to a 4 plug setup if one is used?
thank you for any and all input/constructive criticism.
