Canndspam
I have an '86 2.9L ranger. Typically, when first started cold, it revs high and then drops to its normal idle speed. Recently, when i start it up in the mornings, it has been idling low to the point where it almost cuts off and then revs high, as if to keep itself going and repeats this cycle between 5 and 10 times before it returns to it normal idle. In addition it has occasionally cut off while coasting while driving. Once it cut itself off when I was accelerating onto the highway. When this has happened I have been able to pop it into neutral and restart it immediately. I extracted the codes from it and it read that the egr valve position sensor was reading below minimum voltage, so i replaced said sensor. Now it is throwing codes saying that the egr valve is not opening (which i could care less about) and that the hego sensors say that the engine is running lean. I'm not sure where to go from here. The engine hasn't cut off in the last three days since I replaced the EVP sensor but the startup idle is still strange. Any recommendations?
