stano
- Dec 12, 2008
- Automatic
Hi, I've had this truck (98 ranger4.0) for about a month. Has run well for the first 1500 miles and still does. The engine has 117,000 miles on it but I'm unsure how well it was maintained. Now when the truck is started the exhaust is clear for about 20 seconds and then the engine rpms drop a bit and quite a bit of steam comes out of the exhaust. This continues until the the engine warms completely to operating temperature.( between cold and hot on the gauge). The exhaust does smell a little sweet but not exactly like coolant. The level in the radiator and overflow tank haven't dropped noticably but judging by the amount of steam I am seeing I have to assume the water is coming from the cooling system. The exhaust forms a cloud around the truck when sitting. I am taking it in Monday to have a compression check and leak down if necessary but am just curious, does anyone have any ideas why the steam would start after 20 seconds if idling and coicide with a drop in rpm. Also, if the test don't show any cylinder or head problems, would the intake manifold be the next place to look? Thanks for any help!
