Sporadic miss fixhttp://troubleshootmyvehicle.com/ford/3.0L-3.8L/index-of-articles-1
tmcalavy
Okay, I've posting about the occasional sporadic miss on my 93 XLT with 3.0 engine. Long story short, random hard miss that would come and go regardless of weather, seemed linked to heat as it would pop up most after the truck has been down the road for a couple of hours...but not always. Checked the usual culprits, coil, dist. cap, rotor, plugs, wires, etc. and wound up cleaning plugs, replacing wires, replacing dist. cap and rotor and even the MAF sensor. All of these made it run better but the miss would always return. So I found this website:
and started off with the ignition tests, coil, coil wires, plug wires, dist., etc. and the moved on to the ignition control module test. My ranger has no EGR, old style dist. and ICM on the front fender, way up front by the battery and driver's headlight. I bought an HEI spark tester and LED test light off of Schmebay...gotta have more tools, right?...for less than $20 and went through all the tests. Everything checked out except the ICM, so I dropped $59 for a Standard brand ICM at ABC Auto Parts and the pesky, f-ked up miss seems to have disappeared. So, all told I dropped about $25 on plug wires, $30 on dist. cap and rotor, $20 on tools, $60 on a MAF sensor (unnecessary, probably), and $59 on an ICM to fix this problem...that's $200 more or less, and I coulda save some of that if I had found the troubleshooting website first...probably coulda fixed it for around $20 in tools and $59 for the ICM. But hey, it's a 21-year old Ford so it extracts its pound of flesh and chunks of knuckle from time to time. So, if you're fighting a miss start with the ignition tests and move to slowly until you narrow it down. Mods if you want to move this to the 3.0 graveyard forum, please give it a day or two so some can see this and maybe benefit from it first. Oh yeah, if you do have to replace the fender-mounted ICM you will need a set of deep small sockets to get the ICM off of the heat sink that bolts to the fender. Otherwise, you'll have to do what I did...pry the module off the heat sink, remove the stock tiny bolts and replace them with some similar tiny bolts with Phillips or slotted heads out of your stash of old nuts/bolts/screws, etc. "Fix it up, wear it out, make it do, do without...and never, never throw anything usable away."
So...the ICM was the problem...and it was only $120 over actual cost to fix if you'd known what it was from the get-go...
Not bad, considering...I spent over $200 on parts and lost two days work when my timing belt broke and I couldn't figure it out...experience costs us one way or another...
Good to hear it's finally done for you...and you have some new tools to play with...and shared some good information for others to benefit from...
It will come back to you...:icon_thumby:
Yeah, now I can move on to other stuff...like shocks, recovering the headliner, and maybe pulling the carpet out in favor of putting some bedliner on the floor. As much as the dog rides/travels with me, the carpet just don't work so good...unless you really love the smell of big, wet, sweaty Labs all the time.
I hate buying a specialty tool for a one time use. I dont like buying hardware when I have so much of it around either. I'll take a rusty 10 mm 8.8 . wire brush it 'til it shines. Then I'll make sure the threads are good. Then I use it. I used 3 or 4 BMW axle bolts to replace boogered or sheared bolts when I did the clutch. I would prefer making old hard ware work, rather than buy Chinese stuff. Old stuff has way better quality. :D
I hear ya...my granddad lived through the Depression and helped make me the packrat that I am today. Fortunately, I can find a use for both the HEI spark tester and the LED circuit tester (test light)...which is a pretty cool tool...blinky colors are easier for my bifocals to see when I'm workin' in the garage.
they have them with Blinky Colours? Cool...I want one...:)
Yep, blinky green means ground and blinky red means hot...much snazzier than yer normal flashlight-bulb test light. Plus, now I have 2 lighted home-defense, multi-purpose stabbers in case the Boooger Man sneaks up on me in the garage.
Now I want two...booger men always use the buddy system...after all, we do have two nostrils...
