Spindle bearings
Mike92STX
Zion,Illinois
I am going to replace my spindle bearings. I have the kit that is shown it the tech section but what I took out of the spindle doesn't match exactly. I replaced both differentials on my truck with a set I got from a junk yard so I am planing on replacing bearings in spindles from junk yard so when i take mine off I can just put these on. The bearing are the same but there is a metal flange pressed in probably held a seal and the bearing, none of the other parts shown in picture from tech section. The seal in the kit is all rubber no metal?:icon_confused:
Yeah, I found that out too. Timken SBK4 kit didn't match the oil slinger, so I used a mix of the original slinger, shield, and seal. I prefer the sturdier tight-fitting metal flanged ones over the cheap all-plastic. I'm not impressed, Timken.
See my photos at http://imgur.com/a/d8skq
spindle bearings
I replaced my spindle bearings, before I started it I Googled the question about the seal and it came up with a TRS forum from 2008. The guy on the forum had a NAPA part number for a seal so I checked and the seal was just what I was looking for. Part number is 13144. The only problem is it didn't get rid of the vibration so I replaced all the wheel bearings today. It is snowing so I didn't take it out and do 55 mph to see if the vibration is gone.
also National Oil Seal #710455, same thing as Napa. got mine from advance auto parts for $6.29 + tax.
