2.3L ('83-'97) Spark plug to distributor cable order? 2.3L 1991 Ford Ranger
apfiedler
Portland
2.3 (4 Cylinder)
Hey there Ranger Station,
I made the mistake of hurriedly disconnecting all of the passenger side connector cables while changing my spark plugs and cables and now am unable to find a clear diagram on the routing. If anyone could help with a photo of their 91' 2.3L Ranger spark plugs (passenger side) I would be immensely grateful.
Thanks so much!
Tech Library:
scroll down to "Firing Order"
If the picture on that isn't the most helpful (some years the coil packs were separated, they moved around) assuming you have the stock coils they should be labeled 1/4 on one side and 2/3 on the other side, if you use the connector as a reference you can copy the other side, front to back doesn't matter as there's just two outputs which sometimes helps with routing.
