Back in October our 2002 Explorer spit out a spark plug. At the time we were able to put a new plug in and it stayed. We figured we were on barrowed time.
Well time has run out, it spit out the plug again from the same cylinder. The threads are entirely gone now.
I think this would be the correct kit to fix the thread but not sure.
http://www.amazon.com/ATD-Tools-5410-Thread-Repair/dp/B00A7EMADE?tag=959media-20
It says for 3 valve 4.6L manufactured before 11-30-07 which I think would cover a 2002 4.6L but then it goes on to say "many 2004-2008 Ford, Lincoln and Mercury". Was there something different prior to 2004?
For what it is worth, this 4.6L is not the original engine, it is a remanufactured engine which was put in a few years ago and listed as being for 2002 Explorer. I don't know if it was listed for other model years. I do know the oil filter it takes is not the one auto parts places list for the 2002 Explorer with 4.6L.
Anyone else have any other suggestions? I seen cheaper kits but this one looks like a more solid product than others I have seen.
Dealer wants some outrageous price, like $580 to fix it.
At shop I trust, he has never done the helicoil fix and says he could try but no guarantees and he doesn't think it is a good fix and seen some fail in short time frames. Long and short of it, the only repair he will do that he says he will back involves replacing the head. More expensive than the dealer.
Another shop I have used says no problem, its no big deal. But at first they seemed to say they never done it but then said yes they have done it plenty of times before. This however is the same shop that due to problems such as ignoring the phasing of the right front axle shaft of my B2 has indirectly pushed me to do more work myself. Having done some hole tapping that a little patience goes a long way toward getting a good quality thread as a result and that rushing it may work but you end up with chewed up threads. I just don't know that I trust this shop to do a quality job.
So once again I am looking at kinda learning by doing this myself. I admit I feel a bit, um tentative about it cause if I mess it up like messing up the new hole, stripping new thread or breaking tool off in engine it might mean having to replace the head. Procedurally after looking thru the instructions I think I can do it.
