Dirtmcgurt88
Ok so I bought a 04 ranger xl 2.3 5 spd regular cab shortbed. Might be a possible beach victim. Bought it from a guy who works at a wrecker service that told me fwc called it in to be towed and after 30 days prior owner beings title to avoid towing fees. Guy said it ran and drove. Well wrecker service evidently pulled the plugs and some broke and they vaccumed out the pieces. Then for some reason quit , he didn't know why. I get it home and got to pull the plugs thinking they didn't finish. Well there were none in it and the battery and intake tube as was as the mass airflow was gone. So I get a battery put new terminals on and hook it up and I look inside and the instrument cluster lights were going crazy flickering on and off. The key was off. The longer the battery was connected the lights slowly go out one by one. However once you try and turn the key some lights come back and nothing happens. Only thing I hear is the starter relay. Now the fuse panels (dilemma) under the hood I checked all the fuses and relays and cleaned them up as best as I could. The passenger side kick panel fuse box I was going to pull each fuse individually check and clean where they plug into ( looks like some corrosion). The very first fuse (5amp) I pull on the very bottom left if looking directly at it and it breaks leaving the spades in the fuse panel. I stopped right there. I did replace a ignition switch at the bottom end of the steering column because it was corroded and sticking. But nothing has helped. Now I did find a exact same truck in a junkyard just a 2011 I'm wondering if I should get the under hood fuse box , passenger side kick panel fuse box and PCM and will it work in a 04. Any help is appreciated on where to go or look for. This going to be my son's first truck so it's a project for him and I , sorry for a very long first post.
