strangewayes
- Apr 23, 2017
- Automatic
I just purchased a 1988 Ranger STX to fix up. It has a check engine light but the obd1 port doesn't work, so I'm flying blind as to what it's saying.
When I pulled the PCV valve, it was coated in yellowish goo, along with some inside the valve cover and along the edge of the oil fill cap. Rather thick and snot-like. There does not appear to be anything in the oil when I pull the dipstick. It is honey-colored like it should be. The oil level is not rising.
The radiator lost about 1/3 of a bottle of antifreeze after being driven for 30 miles. No visible leaking anywhere, so its internal.
The engine has a slight miss, but runs well. It smokes a tiny amount on startup but goes away completely after warming up. On the highway after about 15 minutes of driving, it'll start to hesitate if you accelerate at highways speeds.
Do you guys think its a bad intake manifold gasket, or am I going to need to replace head gaskets?
Thanks!
Thanks!
