- Feb 28, 2001
- Dayton Oregon
- 2.3 (4 Cylinder)
- Total Lift
- 6
- Tire Size
- 35"
My house is old and the main heat source is the wood insert fireplace in the living room, air doesn't flow through the threshold to the kitchen very well especially with the beam in the ceiling just in front of the opening... Years ago I found a small ~6" desktop fan at goodwill that I rigged to the door trim to the kitchen... well that fan has had bushing issues for the last couple years and the oil is out of the oilite bushings... any oil I add to it gums up within two weeks... this one looks like a mini oscillating fan and I just bent up some coat hangar wire to clip onto the door molding but for the right fan I'd drill holes somewhere...
Anyone have luck with anything that doesn't break the bank? I don't want something that's loud, something in the 6-8" diameter with a wall mount bracket or something would be perfect... I have 7' ceilings (like I said, old house...) hence the small fan requirement, a 16" fan would take up too much real-estate, the 6" is barely noticeable in the corner of the door frame (no door, ~5' or less wide threshold). I poked around Amazon and everything is either huge, $200, or for camping so far or sounds like it would be too loud... I know I'm looking for a fan in the wrong time of year but I don't think about heat in the summer
