markinms
- Mar 28, 2017
- MS
- Automatic
- Total Lift
- 4"
- Tire Size
- 31 X 10.5 X 15
- My credo
- Duty, Honor, Country
87 BII 4X4.
Brake pedal goes to the floor when applied and must be "pumped" for the brakes to stop the vehicle. Each time the brake pedal is applied I can hear the sound of vacuum being released from a location under the dash.
With the vehicle stopped and turned off, each press of the brake pedal releases more vacuum until it's gone. Usually 4-5 presses.
When the engine is running the brake booster seems to be drawing a great deal of vacuum when the brake pedal is pressed. For example, with engine running the vacuum guage reads steady at 18". Each time the brake pedal is pressed, the reading drops about 5" and with continuous pressing the vacuum guage drops to nearly 0"
I don't know if this has always been this way or just recently started. I'm troubleshooting an engine miss/surge issue and was checking for vacuum leaks when I noticed this.
Any thoughts or suggestions? I'd sure appreciate your help!
Thanks!
Mark
Thanks!
Mark
