serious ticking sound after tranny rebuild!help!
Daniel T.
Hey guys,my bII spent some time in a shop for a complete tranny rebuild.after it was done,something between engine an tranny started ticking real bad,specially when decelerating,is not my engine or tranny its exactly between the two (engine and tranny) any ideas?oil levels are ok,nothing seem loose or unbolted.Any toughts would be appreciated.happy xmas!
Is this the A4LD tranny it could be the flex plate pull the starter and with a socket on the crankshaft bolt turn the crank clockwise while inspecting the flexplate for cracks and check the four bolts for the torque converter are torqued to spec. Maybe take and loosen the four bolts and slowly torque them down snug them first then torque them down to spec.
Yes is the a4ld.Thank you soo much kim will do!
