Sokoji
- Aug 9, 2013
So I just got my first Ford, a 83 ranger with the 2.3 and I'm having a problem when I start it. That being, when the engine is being turned over by the starter, there is a very loud screeching sound. I Thought it may have to do with the starter so I replaced it with another one from the junkyard and it does the same thing. I also checked the flywheel teeth and starter gear and they look good. It makes the sound every time so far and it doesn't seem to matter if the engine is hot or cold and it goes away when you disengage the starter.
Anyone have anymore ideas where I should look ?
