Notch
- Jan 6, 2010
When it does run is it hard to rev/takes long to rev without load on it? One thing I noticed that was left out of your list is coil packs. I've seen similar symptoms (in person, not from descriptions, which makes this a bit harder) that have ended up being a bad coil pack. Because you have a dual plug head, if you want a quick, easy way to see if it is the coil packs, take the two coil packs and switch them around and see if it clears up. It won't garantee results if the coil packs are bad, but if the main coil pack is bad and the secondary one is good, the problem usually becomes a bit better. Also, make sure if you switch them around to check to makes sure that they have good grounds, as they are grounded through the mounting screws into the coil brackets.
Hope this helps.
Hope this helps.
