i see the sway bar still, lol, disconnect that
i think i could put one of my b2s front tires on top of yours, on top of that snow pile and still have the other 3 on the ground.....
86
DO IT DO IT DO IT come up here from ohio! although, my fenders will be in the way....
dont worry, you will be well on your way to a wheeling rig then! i will push them in so they match mine! i need to get pics up of my wave pool fenders.....
86
just remove them you wont miss them trust me
i saw your build thread, they came on 91s?
first off, my b2 is a street legal (really should not be) wheeling rig. i do things with ONLY wheeling capabilities in mind and dont care about how it drives (even when its not safe). with that being said, when i pulled the stock sway bars off my b2 when it was stock i did not feel a note worthy difference on the road.
quick disconnects are much less of a problem for stock trucks that have them removed, the people that should have them on the road are the ones that are heavily modified.
86
well i'll have 33s and a 2inch shackle + a torsion bar crank soon enough, but that still ain't "heavily modified", so i should be fine taking them off altogether or should I rig up a quick disconnect of some sort?
Also, should I do it for both the rear and front?
with the torsion bars cranked i would talk to one of the guys that DDs (or has) and wheels his regarding it. the rear should not be to big of a deal. you have a long enough wheel base the rear can be removed most likely without a problem
86
looks like adam got his 2cents in.....
