79F1504X400
Last night I searched the threads here about 2.9L's running rich and basically I went away thinking coolant temp sensor, MAP sensor or FPR. All of which are new now, and its still running rich. So much that the exhaust stinks. I can drive it. Seems to have the same amount of power, doesnt stumble or hesitate, just sounds funny in the exhaust. It wont start after letting it sit over night, I have to use some ether to get it started, once its warm its no problem. The injectors even sound different, which is hard to explain. I have replaced the ECM, still not 100% sure I got the right one. So does anyone have some ideers/suggestions? Im starting to think maybe I have a couple injectors that could be plugged.
And since I found some broken wires on the FP circuit...the pumps run as soon as you turn the key on....no 2-3sec prime. The fuel pump relay is new....like about 2 weeks old.
