- Jan 19, 2024
- Oregon
- Total Lift
- 1.5 torsion keys
- Tire Size
- 33x12.50r15
- My credo
- Not my F****ng problem.
So like a dummy, I did a little work to some wiring for a TDI in the ranger without disconnecting the battery. Now I have a run-on situation when I turn the key off. I can pull either the PCM relay on the Ford side or the TDI side. Both are wired into the Ford PCM relay to come on like originally intended. The Ford prints say there is a power diode on the Ford side and I'm thinking maybe that. But I can't find it. I'll be back in it this morning. Anything helps. Thanks!
