BigD74
- Feb 17, 2009
I have 99 ranger 3.0 manual 4x4. I locked the motor up tuesday. and luckily i had just bought a parts truck for the gears. so i put the new motor in (it has less than 30,000 miles) and it was really ruff starting at first. after it runs for about 15-30 seconds it smooths out. it only does this when it sits long enough for the motor to cool. it barely runs and on the long periods it takes several start and some pumping the pedal. some times it kicks code but not all the time. P0171 Bank 1 Lean and P0174 Bank 2 Lean. its got new oil and plugs. i doubt its the fuel pump. never had a problem with it before the motor blew. the motor came from a 98 with an auto. i had to switch my motor harness on it. i did reset the computer after i changed the motor. i have put about 50-100 miles on it since the swap. any help would be appreciated thanks
