Yes, ECU(PCM) pin 83 should how about 8volts engine running, or 12v key on engine off.
Wire from IAC valve to pin 83 OK??
Put a test light on the IACs 2 unplugged wires, turn on the key, test light should light up with full 12volts.
Start engine, should see test light getting dimmer and brighter if ECU is pulsing ground to close IAC Valve.
Yes, 1995 to 1997 should be OK, 4.0l Automatic, 2wd or 4wd won't matter, EGR does, so get what you have, i.e. w/EGR or wo/EGR
