BOL
R.C. claims to have redesigned their kit. Do you suppose that means the bracket that punctures the transfer case?
See, it punches a hole in the diff and sends a chuck flying, and then said flying chunk punches a hole in the t case, at least, that's what I hear...
How would it get a chuck into the transfer, a hole punched into the pumkin would push the chunk into the diff not out, And then would have to clear the transmission, to catch the tranfer case!
The spinning ring gear catches said not yet flying chunk and sends it flying, and since it's a reverse rotating diff, it gets sent backwards, out the hole it came in, and since the angle from the diff to the tcase is increased via the 'lift kit' the trajectory of said flying chunk is that in the direction of the tcase, therefore punching said 'hole'.
