Sawboss3
I'm working on a 98 Ranger 4.0, replacing the lower intake gasket. I'm hoping to only replace the gasket. Is there any reason I'd need to remove the fuel rail and injectors before i pull the lower intake?
It came out nicely and I cleaned up the surfaces and was about to install the new gasket, but now I'm confused by the new gaskets. The new ones are not exactly the same as the old one I pulled off. It was all one piece, connected across the middle. Also the openings don't seem to line up. Not sure if I'm missing something or if I was sent the wrong gasket.
