Removing Stock Blocks
WNY964x4
ASE Master Certified
Firefighter
ASE Certified Tech
East Pembroke , NY
i am just finishing up putting in my Skyjacker 2 inch Leveling Coils , my next target is my rear suspension , i want to eliminate the factory blocks , if i swap in a set of explorer leaves and 6400 shackles , will it give me around the same suspension combo as the factor leaves/shackles/blocks , or will it be lower ? thanks for the input
Sounds like it'd pretty much take up what the blocks took out. I'd say do it.
i figured it would be an even swap , and the explorer leaves have more load capacity and it emliminates the little bit of axle wrap i get with the factory blocks
