NefariousDeeds
Hi guys, we broke the original transmission on our 2006 Ranger with the 4.0 and a 5R55E transmission. Bought a good rebuilt unit and we're in the process of swapping it in. We got the old trans out without any issues, transferred over all the sensors and such, and are trying to mate the new trans to the engine block. That sucker will not mate up no matter what we try. I've done quite a few transmissions on other makes and models and they are always a little bit of a struggle to mate but with patience and adjustments, I've always had them eventually pop in without too much hassle. This has been totally different. In and out 5 times last night over about a 4 hour period and tried everything I could think of to get it to slide in all to no avail.
Here's what I've tried:
Ensured the new torque converter is properly seated in the transmission - clicked twice and won't go in any further; input shaft end is even with bell housing surface and converter almost touches the rear of the housing
Checked to make sure the new torque converter and transmission bell housing match the old one - calipers say input shaft is the same size, bell housing looks identical, measures the same
Checked to make sure the alignment pins are properly installed on the engine and have the right holes to line up on in the new trans
Changed the angle on the transmission using two transmission jacks to ensure it was on the same angle as the engine (dang 5R55E has a pan that isn't at all flat on the bottom, built a cradle to hold it)
Ensured the torque converter bolts are lined up with the holes in the flex plate (but the trans won't get close enough for them to go into the flex plate, so I don't believe they are the issue
Got the darn O2 sensor connector out from between the engine and transmission at the top (thought I'd solved the issue) and made sure it and all other wires and cables are not between the engine and transmission
Transmission slides up beautifully to the engine each time, gets to the point where the alignment pins are about to go in and stops like its hitting something. All the bolts line up with the holes in the engine but I won't use the bolts to pull the trans in- something is in the way. It sure feels like the input shaft just isn't sliding into its hole but I don't know how that could be when all the bolts line up. Are these things just difficult to get lined up right or am I missing something? Thanks guys
