cp2295
- Jul 25, 2013
- Washougal, wa
- My credo
- If you ain't first you're last
Hi I'm in the process of rebuilding my 98 4.0 ohv and I'm going to put in a 410 comp cam and want to bump the compression ratio up a point or so. I was reading you can use sohc pistons but I don't know what year to use, and if I'll have valve clearance issues with the higher lift cam. Also as far as pushrods go for the 410 it seems the general consensus is 5.550" length with 3/16" ball end with no oil passage and 5/16" tubes. Is this correct info?
If the sohc pistons aren't gonna work does anyone know where to get high compression pistons for similar price to a set of oem replacements?
