Hi there, i just changed the clutch, flywheel, master, slave and while i was that deep i decided to changed the rear main seal (156k on the engine). well, the drives shift and the clutch engagement is great, but man its leaking oil like a civ.. tearing it all back down this evening. any tips? i used a fel pro "gasket" (its more metal that rubber)
its the correct one for the engine, but i clearly messed up something. any tips or trick would be appreciated. thanks !
FEL-PRO | BS40689 |
