I'm thinking the difference in MC's from non rear disk to rear disk is how much pressure it puts out. With the rear antilock brakes it uses the larger MC so you should still have the right pressure output to operate them. You could probably put a prop valve in there just for tunability but again I haven't done the swap so I'm going on the article from the tech library.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
