ranger on f150 2wd converted to 4x4 frame
rangerdestroyer
just wondering if a 92 ranger well fit on an 88 f150 2wd converted to 4x4 with f250 suspension. well i need to fab my own body mounts or can i use the f150 or ranger body mounts. what problems will i run into and can i even do this build ???
line them up side by side to check the wheel base. depending on the wheel base you may be able to fit the long bed with the extended cab on it. also the f150 frame i believe is wider . so yes you will have to fab up body mounts
