- Jan 12, 2021
- Walkerton Va 23177
- 2.9 V6
- Automatic
- Total Lift
- 3"
- Tire Size
- 31x10.50R15
Really running out of thoughts here. Injectors changed(not ruling out sending them in to get tested) temp sensors all swapped and working, MAP new(since rebuild) timing quadruple checked, plugs changed again, sprayed 3 cans of brake clean around engine no leaks found, fuel pressure good... I'm sure I missed something. New O2. Runs terrible when cold, the hotter it gets, the better. IE like 20-30 minutes of runtime under load at 90+ degrees it almost goes away. Sits 20 minutes right back to acting up. Still only under low load.
