JimRummy
- Aug 23, 2010
- Age
- 39
- Los Angeles, CA
- Automatic
I just wanted to see if one (or more) of these issues are relating to something failing, or getting ready to fail.
I have a 93 4.0 AT 2WD. The brakes have always kinda sucked, but they are worse then they've been recently. I noticed some fluid coming out of the rear drums, and getting on the wheels. Not a lot, but enough to notice. I recall reading that you can tell if its brake fluid, or diffy fluid by rubbing it between your fingers and seeing if i becomes gummy. Well unfortunately it had already dried too much for me to do that, and hasn't done it since. I took it in to have the fluid flushed (I cannot work on it at my apartment) and they told me there was no life left on the shoes, the wheel cylinders were failing , and it would continue to leak and feel spongy until I give them hundreds of dollars, yada yada you know the spiel. Anyway I take it to my parents house and replace the shoes (which were not all the way gone btw). It gets better, but still not great. Before doing the shoes the pedal went 3/5 to the floor before it bites, and never really felt good, like when you are almost to a complete stop the pedal sinks more, and you have to push harder when going slower for whatever reason. The pedal always seemed to fade at stops, and almost seemed to require additional pressure the longer you are stopped. After swapping out shoes, the fluid leakage has stopped (or at least slowed to the point of not noticing).
ANYWAY after a few weeks, and reading around I decided to pull the ABS fuse and see how she drove. Drove decent, a little better but still not perfect. After a week without ABS I put the fuse back in, and now my brakes are the best they've been for years.. The pedal only has to travel maybe 2 or 3 inches to start to bite, as apposed to 3/5 depressed. They feel good, but not confidence inspiring.
On Friday I helped my buddy move his boat (about a 10 mile drive) and the brakes worked, but at times needed to be floored to get it to stop, and this is not a big, or heavy boat. Since moving the boat I feel like they are worse then they were before Friday, but better then they were a week or 2 ago.. Dunno if I'm tripping or what, but now that I have a 8 month old daughter (and with no air bags or anything) safety is a big concern, and for a 20 years old truck I'm not sure exactly where I stand on a lot of these things.
Sorry for the huge post, but I type like I talk, so it can take a while.
Any input is appreciated, you guys are the best.
