RABS riot
what I found on the bottom shelf of the bookcase out of sight behind some stuff.
1995 explorer evtm
1995 aerostar evtm
1995 ranger evtm
1995 Aerostar Ranger explorer powertrain,drivetrain
Powertrain control/Emissions Diagnosis 1995 Service Manual
1995 Aerostar, Ranger, Explorer Body Chassis Service manual. I used that for RABS
And a Haynes ford explorer 1991 to 2001 Service Manual.
I'm impressed. Sounds like you have a bigger RPC (Ranger Porn Collection) than I do.
Well done on fixing the RABS issue. (y)
If that solves it I will have an untested ford brake modulator control for sale for $40.00 shipping included.
If your light stays out I may hit you up on that modulator down the line here.
I tell the boss lady I am watching auto engineering porn. Pine Hollow, Scanner Danner, South Main Auto,Schrodingers Box have helped my thought process and diagnostic skills immeasurably. I need that kind of reinforcement to break old habits.
Cold War Motors when I want to see someone dream of auto restoration in three d and have mad fabrication skills.
Project Farm before I spend money.
Things are no longer as simple as flat head sixes.
I had seen a use sheet for the RABS valve. When I searched on flea bay they were asking crazy money that was more than dorman.
98-00 MAZDA B4000 PICKUP Anti-lock Brake Parts Assembly 2 Wheel Oe# Zzp0437a0a is what I ordered and it looks to be exactly the same.
I am a professional Idiot and what I do should not be followed blindly, lest all of us drown.
From Cardone
Ford Bronco 1989-1990
Explorer 1991-1992
F-100 1996-1998
Ranger 1989-1998
Mazda B-Series 1994
Navajo 1991-1992 more details on - https://www.carid.com/sf-pl-mpn/pid...PG_rlW5byP4qZFkweMxoCYEUQAvD_BwE&gclsrc=aw.ds
Hope this helps with your pick and pull adventures. As simple as this valve is I would suspect that many problems with the ABS light may be improper bleeding. Brake adjustment. Or improper resetting, as was the problem in my case.
This is RABSwhat came in from a yard in S.C. I don't believe the condition. and I don't need it
I wonder if they have other stuff I need.
Barnettes Auto Parts Inc.
do a great job of shipping and packing.
