RABS Control Module
Rangerdude
Greensboro
Hello Everyone,
I would like to know if any of you all have a clue what is going on with my truck. I have a 1992 Ford Ranger and I have already got the code, it was a code 3 I believe it went ..._ . I replaced the RABS Control Module with a fresh one after going through the mechanics guides(found else where here and will be attached and now it will not respond to the diagnostic sensor and does not show the parking brake light when it is engaged. Any and all help will be appreciated.
Thanks,
Rangerdude
Update:
Turns out I could get a code and it ran a code 16 and therefore is good, however the red brake light is not working still.
Update:
Have you verified that the bulb is good? It could be that it’s just burned out.
It might be however upon testing the switch it showed OL for both positions so I have a switch in the mail. However, I will check the bulb tomorrow.
Thanks,
Rangerdude
