Quiz for TRS Chapter 2
reno
Quiz for Chapter 2
1. Which of the following are
examples of systems?
a. clock
b. electric dishwasher
c. communication network
d. society
e. all of the above
2. Block diagrams are developed in
what type of analysis?
a. physical
b. quantitative
c. qualitative
3. Specific system parameters are determined
in what type of analysis?
a. physical
b. quantitative
c. qualitative
4. What is a sensor used for?
a. to convert a nonelectrical
input to an electrical output
b. to convert an electrical input
to a mechanical output
c. to reduce the effects of noise
and other disturbances on the
measured quantity
d. all of the above
5. What does an actuator do?
a. converts a nonelectrical input
b. converts an electrical input to
an action
c. reduces the effects of noise
measured quantity
d. all of the above
6. What does signal processing do?
a. converts a mechanical input
a mechanical output
measured quantity
d. all of the above
7. An error amplifier is used to
compare which of the following
two signals?
a. the output of a sensor and the
input to a signal processor
b. the output of a system and the
command input of a system
c. the output of a signal
processor and the output of a
system
d. none of the above
8. A basic instrumentation system
consists of which of the following
components?
a. sensor
b. actuator
c. signal processor
d. all of the above
9. A control system may contain
components?
a. error amplifier
b. control logic
c. plant
d. all of the above
10. Which of the following are
examples of a plant?
a. automotive drivetrain
b. high-temperature oven
c. an airplane navigation system
d. all of the above
I don't have to these quizzes, i figured it would be fun, if you guys want, I will upload this e-book for you to download and read it yourself if you want.
uummm........wtf? guess i will wait for chapter 3? chapter 1 wasnt bad, but i know like 2 of those answers.
the book is in Adobe format, if I knew how to Edit the book, I would upload the book without the answer key so everyone could read the chapter and answer the quiz.
I found this E-book called Understanding Automotive Electronics. It has Quizzes in it, and I figured that it would be fun to take a quiz to see how far you are and what areas you should brush up on.
Are you sure it's legal to do this?
There have been issues with other sites stealing information from this one. I'd hate to see us do the reverse.
There is almost certainly a copyright notice of one sort or another. See if it allows reproduction. It might. But it's really appropriate here to cite it with each post.
I'm curious what these guys consider a "plant" to be.
I'll check for the Copy right, but I found this on a site that had hundreds of E-books, from recipes to gardening to house hold to automotive.
