I was gonna start calling around to some salvage yards to try and put together the stuff to convert my 88 Ranger 2.3, 5spd to 4wd.
As far as the transmission, can the tail housing just be swapped off for a 4wd model or does it need a whole new trans? If so I would assume the tailhousing has to be from another M5OD correct?
Are there any quirks as far as a transfer case or would any model from a 1st and 2nd gen Ranger and 1st gen Explorer work? I prefer electric shift, the cab is cramped enough as it is.
As far as the front end also, I see they switched from the Dana 28 to the 35 (same gearset one of my old Jeeps had, but in the rear end), but are they cross compatible? Compatible with the 1st gen Explorer also?
I think my truck has the Ford 7.5 rear end, but I want to upgrade to the 8.8, what models had them and which ones bolt in? I can handle welding on brackets for the springs and shocks, but would rather not if I can avoid it.
As far as driveshafts, are the Explorer fronts compatible?
Last question, is there a chart somewhere that lists the fd ratios for different models and packages? Or is there at least an easy way to tell from a tag or something besides rotating them?
I'm not looking to build anything for the trails, I just want my future DD truck to have 4wd. Not gonna run anything bigger than like 30"s
Thanks for the help, i'm sort of new to Rangers and Ford stuff but I've been working on Jeeps for years.
