I'm new to this system of 4x4, having only been exposed to the '93 F150 Dana 44. I now have a 2000 Ranger XLT, extended (super?) cab, 4.0 4X4. Before I got the truck, it had been in an accident, crunching the front left side, so the spindle was replaced. I found that the vacuum line on that spindle had fallen off, so I reconnected it, but suspected something just wasn't right. I raised up the front end and manually spun the wheels. I found the left hub was still locked. So I took it apart, cleaned it, unlocked it. Fine. What I would like to know is, when the switch is in the 2wd position, what is supposed to be spinning when the truck is in gear with all 4 wheels OFF the ground. The shaft from the trans to the T-case? The shaft to the front end? The shafts to the two front wheels? What exactly does the t-case motor controller do? Sorry for my ignorance, but I really miss that 4wd shift lever on the floor.
